disable STP on SG200?
mdschomburg
I am trying to connect an SG200 to a customer's existing network. The customer does not want to receive any bpdu frames from the SG200. The customer's port has bpdu guard configured to err-disable their port upon receipt of a bpdu.
How do I completely disable spanning tree on the SG200 so that it does not send any bpdus?
jimmysands73_2
Level 5
Level 5
BPDU Filter would disable sending/recv'g (processing) any BPDUs I believe.
Its the equipvilant of turning off spanning tree.
I have never worked on that model, but found this:
http://www.cisco.com/en/US/docs/switches/lan/csbss/sg200/administration_guide/78-19562.pdf
page 119 has your answer.
Edit: On page 121 its list how to disable spanning tree per port.
jimmysands73_2
Level 5
Level 5
Jan Rolny
Level 3
Level 3
Hi Mike,
you should not disable STP functionality on switch because it prevents forming loops. So customer switch port connected to your swtch should be configured respectively.
I think you cannot disable STP on whole switch. You can just stop it on port basis with this commands.
spanning-tree portfast
spanning-tree bpdufilter enable
But i strongly do not recommend it to you.
Jan
Hello
I agree with JAN
I wouldn't disable STP  also BPDU filtering, If applied on a interface,  will filter BPDUs regardless of portfast operational state - as stated, Its the same as disabling spanning tree on that port and could result in spanning-tree loops.
I suppose you could use the switch as a hub switch and attached it via a access port assigned to one specific vlan, but again its really not recomended.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
