Does anyone know how to get the current config of a WS-CE500-24LC switch?
alexoncisco
We are going to replace three WS-CE500-24LC switches with SG220-26P switches.  I would like to get the current config from the Catalyst Express 500s to either 1. import into the new devices or 2. at least use the current configuration to see settings that may have to be updated on the new switches.
Charles Hill
Duplicate posting........********************************
Not sure why the posting below is replicated several times.  I don't see the posting when I attempt to edit.  Any way this is a duplicate.
""You can restore your configuration settings by using Network Assistant to save the
switch configuration file. After saving the configuration file, you must use the
device manager Restart / Reset window to reset the switch. After resetting the
switch, use the Express Setup window to assign a switch IP address and to assign
the same host name that was used before the switch was reset. Then you can load
the configuration file to the switch and restore the previous configuration settings.
For information about saving configuration files, see the Network Assistant
documentation."
See link below for the user guide .
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalystexpress500/release_12-2_25_fy/user/guide/ug.pdf
 You can download Network Assistant at the link below.
https://software.cisco.com/download/release.html?mdfid=280771500&softwareid=280775097&release=5.6.3&relind=AVAILABLE&rellifecycle=&reltype=latest&i=mmp
Hope this helps,
Please rate helpful posts.
Thanks.
- See more at: https://supportforums.cisco.com/discussion/12532511/does-anyone-know-how-get-current-config-ws-ce500-24lc-switch#sthash.miz3ncWo.dpuf
Hey alexoncisco,
documentation."
Hope this helps,
Thanks.
- See more at: https://supportforums.cisco.com/discussion/12532511/does-anyone-know-how-get-current-config-ws-ce500-24lc-switch#sthash.gUkQ1mSP.dpuf
Hey alexoncisco,
documentation."
Hope this helps,
Thanks.
