04-05-2022 10:20 AM
Kindly advise which cisco 8 port switch can support port forwarding and NAT to give public access from Internet to secure server in office behind switch
04-05-2022 11:20 AM
Look for any RV - Models (bare in mind these go end of life soon)
04-05-2022 06:56 PM
Which other router can i use of less cost in place of rv for port forwarding
Is isr1102-4p ok or 800 or 900 series
04-06-2022 12:43 AM
That is correct, those are the next level, enterprise models and the Meraki Go security gateway and Meraki cloud-based SD-WAN appliances (https://meraki.cisco.com/products/security-sd-wan/ and https://www.meraki-go.com/products/security-gateway/ )There will be entry-level CBR (Cisco Business Router) but yet we could not commit any timeline.
04-05-2022 11:59 AM
None of the CBS and entry-level Cisco switches does support NAT. You can take a look at Cat4K and Cat6K switches.
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/29283-166.html
