返信
Does The SG300-10 Support RIP?
Hi!
In the CLI documentation for the SG 300 Series, it shows sh ip route rip as a command. I have installed the latest firmware and that command is no longer available. Does the SG300 series support RIP?
Thanks!
Richard S.
1 件の受理された解決策
受理された解決策
davidagu
Hello Richard,
My name is David Aguilar, and I am an engineer with the Cisco Small Business Center. Thanks for writing.
The SG300 Series does not support RIP. Only static routes (maximum of 32) are supported. However, the SG500X models support the RIP version 2 dynamic routing protocol.
In regards to the new Sx300 firmware, it did add a number of impressive security features including IP ARP inspection, DHCP snooping, and SSD encryption.
All the best,
-David Aguilar
Cisco Small Business Support Center
元の投稿で解決策を見る
7件の返信7
davidagu
Hello Richard,
All the best,
-David Aguilar
can I ask you where can I find new 1.2.5 firmware verison? I was unable to find it.
Thank you!
Best wishes,
Marko
Marko,
The 1.2.5.70 firmware has been pulled by the business unit. Please continue to use the 1.1.2.0 firmware
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I knew it was too good to last... Will it be added back?
Marko, please follow this post for updates;
https://supportforums.cisco.com/docs/DOC-25157
Thank you!
Best wishes,
Marko
Does Cisco SG300-28 support Dynamic routing in L3 mode now ? I want to check because I can see there is an update in firmware.
