01-06-2015 06:20 PM
I connot connect to SG200-50FP out of the box using Telnet. Web interface works ok, How do I enable Telnet on the switch?
01-06-2015 07:34 PM
The SG200 has no CLI interface, so there's no way to enable telnet or SSH access. If you need a switch with a CLI, you should look at an SG220 or better.
01-06-2015 11:41 PM
Jody, Is there a way to configure multiple ports at once, such as making ports 2 through 24 configured to access ports and vlan2?
01-07-2015 12:15 AM
I believe you can achieve this by first configuring Port 2 under Vlan Management -> Interface Settings and place it into the correct Vlan.
Then select Port 2 from the same screen after editing the Vlan, click "Copy settings" and enter "3-24" as the interface range.
01-07-2015 08:10 AM
Nathan's summed it up well. The "copy settings" option is your friend when dealing with those units.
08-20-2015 06:50 AM
There is no official support, however telnet can be enabled by following steps (if you do so, you will probably void your warranty, God kills a kitten and other evil things happen):
You can verify that the telnet is enabled in web interface under Security -> TCP/UDP Services. Look for line which begins with Telnet in TCP Service Table. Port telnet server is listening on is in Local Port column.
Snip of running-config.txt:
username cisco password encrypted xxxxx privilege 15
ip telnet server
interface gigabitethernet1
09-10-2015 10:01 AM
Good info! Sometimes you just need a CLI to do some simple testing!
The only thing I found (on an SG200-26) is that the default username (cisco) didn't authenticate using telnet. I had to add a secondary user account, which authenticates just fine.
09-10-2015 12:59 PM
hi Jan
great info. Few months ago I did same trick with adding "ip telnet server" but I thought that it was simply not working. I didnt realized that telnet just started, but on nonstandard port! Thanks for this final revealing :-)
unfortunately now I guess they will block this in future firmware versions. at least we can see that this is purely marketing-related restriction :-(
thank you anyway for letting us know
07-04-2016 10:18 PM
Thanks Jan.. very useful infor... i had few problems with gui.. cli is the best ...
01-19-2023 01:09 AM
Thanks for this
It's working
