01-26-2019 05:30 AM
I have an AccessPoint WAP 551 powered by PoE by a Switch SG300-10P. However, some time when I try to connect to the wifi, I have to make several attempts for the connection to be accepted.
Here are the AccessPoint WAP 551 connection logs:
Dec 31 2018 14:45:03 err hostapd[5086] trying to deauthenticate to station XX:XX:XX:XX:XX:XX, but not authenticated
Dec 31 2018 14:45:00 err hostapd[5086] trying to deauthenticate to station XX:XX:XX:XX:XX:XX, but not authenticated
Dec 31 2018 14:44:57 err hostapd[5086] trying to deauthenticate to station XX:XX:XX:XX:XX:XX, but not authenticated
Advised by a cisco forum, I disabled the MFP parameter. I looked the all parameters configuration, but I found nothing abnormal. I hope you have a solution, because I gave up (I am tired) ...
Thank you in Advance
Solved! Go to Solution.
02-20-2019 02:17 AM
We finally found the solution. By simply replacing the Cat5e UTP cable with a Cat5e SFTP.
01-29-2019 02:27 AM
I'm very disappointed for the support Cisco because this issue prevents us to work.
It's the last each to I buy a Cisco networking material, I think the Dell's network is better (pricing and software) than Cisco's.
So I will change all Cisco hardware to Dell.
Thank you to have confirmed this
02-20-2019 02:17 AM
