Error Authenticating to Tacacs server
freqeuncyhop
I am trying to configure TACACS+ on a CBS350 switch but any authentication efforts fail with this error message:
%AAA-W-TACACSAUTHEN: Received unsupported authentication REPLY msg status=7 (server msg: Inconsistent lengths)
and then it defaults back to local authentication.
Here is my AAA config:
#show run | inc aaa
ip http authentication aaa login-authentication login-authorization tacacs local
aaa authentication login company tacacs local
aaa authentication enable company tacacs
aaa authentication login authorization default tacacs local
aaa authentication enable default tacacs
aaa accounting login start-stop group tacacs+
and TACACS config
encrypted tacacs-server host <ip-add> single-connection key <passkey>
tacacs-server timeout 30
tacacs-server host source-interface vlan <int>
balaji.bandi
what TACACS+ Server are you using? what logs do you see on the TACACS side?
Also see may AAA configured ?
Do some basic config and test it :
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-350-cli-/aaa_commands.html?bookSearch=true
#telnet TACACSIP  49  < is this works ?
BB
