11-08-2022 03:40 AM
Good day,
I searching for official documentation/diagramm how the airflow is working in the SG550XG models.
Thx,
MaDe
Solved! Go to Solution.
11-08-2022 05:29 AM
Hi MaDe,
The airflow path is from left to right. Do not wall-mount the switch with its front panel facing up. Following safety regulations, wall mount the switch with its front panel facing down or to the side to prevent airflow restriction and to provide easier access to the cables.
11-08-2022 04:23 AM
Most of the cisco switches (other than nexus and chasis) as i know front to rear.
11-08-2022 04:28 AM
thanks for your reply. the SG models have their fans on the side. I would like to know if there is also an intake and outtake.
11-08-2022 05:29 AM
Hi MaDe,
11-08-2022 05:49 AM
thanks for the info. Is there a diagram or a sheet you can share for me?
Thx,
MaDe
11-08-2022 08:30 AM
There is no such official documentation we could provide at this point.
