I have a server that runs Windows 2003-R2 with an UGI Transoft Unix emulator running accounting software. All the clients connect via telnet. Durring a session, there are 2 proceedures that if we do them, they flash a bunch of numbers via the emulator/telnet session as if the server was paging thru the data, updating the telnet session with what it is doing. When this happens, the Cisco Switch ESW520 disables the port its connected to, and I end up having to reboot the server for it to get connection to the network again. Does anyone know how I can check the logs on the ESW520 to see what is happening? Thanks in advance, Bill
