Protocols for switches 300 series and 500 series
These protocols are supported by switches of the 300 series and 500 series?
  • TCP
  • UDP/Unicast
  • UDP/Multicast
  • UPnP
  • RTCP
  • RTSP
zbenko
Dear Alejandro,
If you mean weather the switch can pass through these protocols the answer is a definite yes. If you meant something else can you please describe what you meant?
For example TCP is supported in a manner that it can filter trafic based on TCP port (Layer 3+ functionality), so can it do for UDP. Multicast is also handled via IGMP support. Regarding RTCP and RTSP how / for what  would you use it?
Thanks and regards,
Zsolt
zbenko
Dear Alejandro,
Thanks and regards,
Zsolt
The application for these switches is to manage IP Megapixel cameras
