ESW500 port speed issue
jscibelli
I have an ESW500 switch with Cisco 2800 routers connected to 2 of the ports. The routers are provided by and managed by
an outside vendor. The ethernet connections for each router are showing as 100mbs/half duplex. The vendor insists that the
ethernet connections are configuerd at 100/Full (see below). The ports are set at Max capability. If I try to specify 100/full on the switch port the port shuts down.
Does anyone have any idea what the problem can be?
Thanks in advance
Joe
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 1c17.d338.5868 (bia 1c17.d338.5868)
Internet address is 65.249.134.172/27
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Last input 00:00:03, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute output rate 541000 bits/sec, 63 packets/sec
2766989 packets input, 194933803 bytes
Received 2666752 broadcasts, 0 runts, 0 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 1 ignored
0 watchdog
207163794 packets output, 3096694402 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
135648 unknown protocol drops
0 lost carrier, 0 no carrier
jscibelli
Just an FYI I finally found a vendor contact who resolved the problem. The Cisco router was hardcoded to 100/full, the switch port set to auto negotiate.
Onc the tech changed the router to auto negotiate the connections came up at 100/full. There is some sort of compatibilty issue (even though they are both Cisco products) If I hardcoded the switch port to 100/full with the original router setting of 100/full the switch port would go down.
