Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2800 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4338 Views
  • 1 replies
  • 16 Helpful votes
Have an SRW2024 switch and need to capture log entries. I'd like to capture the entries on a Windows server, using syslog orwhatever method will work best.  I'm just not familiar with how to setthis up and get it working.Is there documentation out th...
arphilyaw by Level 1
  • 920 Views
  • 2 replies
Hi,I like to sepearte a private from a business network in the same IP-range (192.168.1.0) with one Gateway (192.168.1.1).So  I create three port-based VLANs ID10 for private (Ports 1-10), ID20 for  business (port 11-20) and ID 30 (port 23) to access...
fg by Level 1
  • 991 Views
  • 2 replies
We just got a Cisco SG300-10P switch in to install at a location within our network (small area, thought it would be better to put them own their own VLAN segment) and this thing is NOT what we anticipated having. Without IOS (and a CLI) we are havin...
portenier by Level 1
  • 1456 Views
  • 0 replies
I have an ESW500 switch with Cisco 2800 routers connected to 2 of the ports. The routers are provided by and managed byan outside vendor. The ethernet connections for each router are showing as 100mbs/half duplex. The vendor insists that theethernet ...
jscibelli by Level 1
  • 561 Views
  • 1 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
