EtherChannel
ssnachy0
I am doing a lab in GNS for EtherChannel facing issue.
below are thinks done with both switches..
1. port range f1/1 - 3
2. channel-group 1 mode on
3. switchport mode trunk
when doing :- show interface trunk its showing status not-trunking.
2 Accepted Solutions
Jitendra Kumar
your process amazing for making etherchannel
your ports will be in Suspend mode by your method.
Anyway follow below steps
1-interafce range
2. switch port mode trunk
3.channel-group 1 mode on
in your lab below steps should be enough.
in current senerio go on port-channel group and make it trunk--- if its work for you..
Jitendra
Jitendra
Jitendra Kumar
keep remember 1st you need to make trunk then channel-group..
Enjoy.. Buddy
Jitendra
Jitendra
balaji.bandi
What Switch image are you using in GNS3 ?
try shut and no shut both the sides. - still not coming up
check is the interface in admin mode up ? show interface fa1/1 to 1/3
Note : Most of the best practice even ports, that means should be 2 or 4 or 6 example ? Looks like you try to make 3 ports in PO not a best practice, but can be done.
BB
Jitendra Kumar
1-interafce range
Jitendra
Jitendra
ssnachy0
Yes port was in suspend status .
just try port-channel 1  and make trunk command on this now its showing Up in use.
Jitendra Kumar
Enjoy.. Buddy
Jitendra
Jitendra
