EWS-520-24POE Cant Power AP1131
hj
Hey i have this issu with a Cisco AP1131 it keeps saying:
Due to insufficient inline power. Upgrade inline power source or install power injector.
I have 4 Accesspoint on the switch and thats all.
chrcoope
The 1131 supports both ILP and 802.3af. It is likely that "config ap power pre-standard enable" is configured. I would post here and ask how to set it for 802.3af exclusively.
Christopher
Thank you for your question.  This community is for Cisco Small Business products and your question is in reference to a Cisco Elite/Classic product.  Please post your question in the Cisco NetPro forums located here: http://forums.cisco.com/eforum/servlet/NetProf?page=main  This forum has subject matter experts on Cisco Elite/Classic products that may be able to answer your question.
SB Support Community Support Area ----> NetPro Forum
- Voice and Conferencing ----> Unified Communications and Video Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Unified_Communications_and_Video_discussion
- Security and Surveillance ----> Security Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Security_discussion
- Wireless ----> Wireless - Mobility http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Wireless_-_Mobility_discussion
- Network Storage ----> Data Center Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Data_Center_discussion
- Routers ----> Network Infrastructure Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Network_Infrastructure_discussion
- Switches ----> Network Infrastructure Forum http://forum.cisco.com/eforum/servlet/NetProf;jsessionid=E0EEC3D9CB4E5165ED16933737822748.SJ3A?page=Network_Infrastructure_discussion
alissitz
Level 4
Level 4
Hello, I hope this finds you doing well.
Please upgrade the firmware to 2.0.3.  Here is a link with helpful resources as well as a link to the firmware:
https://www.myciscocommunity.com/docs/DOC-7615
I do not have a reference page to point to, but as I understand it the negotiation of POE for these APs is fixed with the latest firmware.  Please check the version that you are running and or upgrade.
Can you update us when you are done?  Many thanks in advance, kindest regards,
Andrew
I upgrande the switch today and it work :) so now the AP is up and running.
Thanks guys
Glad to hear it!!!  Have a great day,
Andrew
