05-13-2015 02:44 AM
I am using Cisco SG3000-28 Switch i forgot my username password .
I want to knew my username and password .Kindly help me to resolve.
05-13-2015 04:13 AM
You need to reser the switch which will lead to config loass i.e. you need to reconfigure the whole switch again.
How-to
Rboot the managed switch, press the Reset button for less than 10 seconds.
Cisco doc
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
05-13-2015 05:28 AM
I don't have access to a sg300-28, but it looks like a password recovery may be possible without losing the config.
Below info is from a previous posting.
https://supportforums.cisco.com/discussion/12215636/sg300-how-recovery-password-cli
In order to reset the password from the boot menu you need to interrupt the boot process of the switch. Console in and power cycle the switch, you should see the Cisco logo, then you have about two seconds to hit a key to get the boot menu. If you miss it (or it times out once your in it) just power cycle the switch again to bring it up again. On the switch in front of me it is option 3 to reset the password. - See more at:
Here is another posting that discusses password recovery on a sg300 switch.
https://supportforums.cisco.com/discussion/11741646/sg300-28-forgot-password
Hope this helps,
Please rate helpful answers.
Thanks.
05-13-2015 05:33 AM
Are you able to see the document
https://supportforums.cisco.com/docs/DOC-27000#sthash.LFXO7Z2C.dpuf
For me it shows - You are not authorized to access this page.
05-13-2015 05:49 AM
No, I could not access it either. Don't know whats up with that page?
That's why I posted the other posting as well.
05-15-2015 08:40 AM
First of all save your current configurations.
From Reset button, reset switch and load saved configurations.
Jerry Paul
05-15-2015 02:21 PM
Hello jkmferrotech,
Thanks for using the Cisco Small Business Support Community. I'm sorry to hear that you forgot your username and password, and I hope that we can help you find a solution.
There is a password recovery procedure that allows you to manually configure a new username and password. I have found the step-by-step document on the Cisco Knowledge Base that can help you do this:
Administrator Password Recovery for 300 and 500 Series Managed Switches
(Note that, you will have to access the Command Line Interface (CLI) on the Switch in order to do this. Step-by-step instructions on how to access the CLI can be found here.)
I hope you will find this answer useful.
If this post solves your issue, please remember to mark your question as resolved and rate any helpful posts to help other members in the community! Thanks!
all the best,
Ruben
