Hi all, I need a small help with my Cisco SG200-26 (not PoE model). After a power failure, at restart the switch seems unable to reboot. The power led starts blinking in green, after some seconds the connected ports start blinking as well, but the the switch reboots automatically after few more seconds.
I tried to disconnect lan cables, power cord, and reset to factory by pressing and holding down the proper button for 30s and more, but no success.
In the small amount of time the switch's ports seem to be powered up, clients don't receive packets, don't ping each other or the switch manage address.
Is it an hw fault? Is it impossible to restore?
Thanks in advice, and excuse for my english.
Andrea Gumirato
vashkenazy@libero.it
Italy
