04-28-2015 01:04 AM
I like to block certain IP and website on the SG 300-20.
Being new to Cisco Small Business switch I she tried with no positive result. Could someone give me some steps or maybe direct me where I can find a step by step resource.
Thank you
05-04-2015 12:05 AM
Is this not possible?
05-04-2015 06:01 AM
Thank you for contacting us for support with your device.
Unfortunately what you are trying to do is not possible with any Small Business switch.
It is true that this switch can be used in layer 3 and it will be able to route your traffic on the inside of the network, but it will not be able to route your traffic to the Internet as it doesn't do any NATting.
If you need to block any websites you will need to configure it on your router or firewall.
Just to be completely clear, this switch won't be able to block any websites.
I hope this was helpful
05-04-2015 06:15 AM
Thank you for the response.
I was able to block certain website by adding a DENY rule in a ACE list.
Is this not a optimal solution?
Thank you
02-04-2020 03:03 AM
can you please explain to me in detail. I also want to block a particular website
