Help Guys, need memory OIDs for SG350
ABLESECU
I downloaded MIB Files for Cisco 350. but It's very difficult to monitor my SG350 appliance and I couldn't check memory status of SG350.
I need memory OID for SG350 for monitor SNMP.
psandel
My name is Puneet Sandel and I am Cisco network engineer providing technical support on small business devices. As per your query regarding memory utilization OIDs for SG350 switch, please find below the 2 OIDs that you can use to monitor memory utilization using SNMP.
ciscoMemoryPoolUsed : .1.3.6.1.4.1.9.9.48.1.1.1.5
ciscoMemoryPoolFree : .1.3.6.1.4.1.9.9.48.1.1.1.6
In case you face any issue feel free to contact Cisco frontline number and get a case opened with Cisco. We will definitely help you out with the issue.
You can contact Cisco by clicking the link given below.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Puneet Sandel
Technical Consulting Engineer
Global CX Centers – Small Business Support
8 Replies 8
psandel
Puneet Sandel
Hello there,
I check the two proposed OIDs for my case and does not work. Are there any other i can try?
I have the same switch SG350-10 but unfortunately I am struggling to find the OID for RAM, i could only find for CPU.
Thanks in advance
What OID is for CPU?
And provided OIDs for RAM do not work for me either...
I am using this key for CPU usage
1.3.6.1.4.1.9.6.1.101.1.9.0
Thank You :)
Have you managed to find RAM utilization OIDs?
Not yet
Hi - provided OIDs for memory utilization don't work for me. We have SG350-10
liyua
Hi, it's different from catalyst, for SMB device, there is no memory OID.It could be check by  command 「show tech memory」
