08-28-2009 10:16 PM
I need help with password recovery on SRW224G4P. I couldn't get into the MENU by press ESC to interrupt the normal boot process. I tried many many times, no luck at all.
Below is what I see during boot up process:
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
User Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... PASS
DRAM Test .................... PASS
Timer Test ................... PASS
Done All Pass.
------------------ DONE ---------------------
Loading Runtime Image File : SRW224G4P_SRW248G4P_image.bix
Runtime 1.0.2
Pass
root init done
Set Transition mode ...
[get stackingMac done ret_val] = 1
Assigned Unit ID:[1]
stacking DB: unit = 0, module type = 0
Finish Set Transition mode ...
Enter Transition mode ...
Finish Transition mode ...
Enter Master mode ...
Load certificate files : Starting
Load certificate files : Finished
Finish Master mode ...
Performing startup provision ...
CLI enter main (PROVISION)
Notify provision complete
CLI provision has been completed
Provision Complete ...
Finish Provision Complete ...
XFER: End of config sync.
Please press <Enter> to start Menu session!
Please help, let me know where I should press ESC or any other key....
08-31-2009 03:48 AM
Pls help.....
08-31-2009 06:26 AM
Use this procedure. I tested it in my lab with your model switch and it worked here.
Christopher
06-24-2010 08:33 AM
Ctrl+U should make it on the boot process, and then reset to default configuration
06-28-2010 06:31 AM
Diagnostic 1.0.1
User Mode
Done All Pass.
Runtime 1.0.2
Pass
root init doneSet Transition mode ...
stacking DB: unit = 0, module type = 0Finish Set Transition mode ...
Load certificate files : FinishedFinish Master mode ...
In order for you to reset the SRW224G4P you need to use a Data cable and use the console port of the switch. Once you are on the Console screen you could do a hardware reset.
Check out the below link for more information
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
