Hi, need a solution for problem
uddin9101
hi, i have a priblem in connecting antminers only 4 come online and if i remove this 4 then the other 4 online and i take new ips of 1 gbps then i connect more 4 and i have 50 pic and i want to connect to 1 isp can u suggest any option or metherd
Seb Rupik
Hi there,
From your description it could be that you have a very small DHCP pool which can only accommodate four hosts, or perhaps you have a very restrictive NAT/ IP ACL which permits only four IPs from the 'inside' network. Ideally we really need to see that configurations of the devices you are connected to.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
how to do this
setting little detail
Hi there,
Can you share the config of your network devices in question and we can comment on what needs adding/ adjusting.
cheers,
Seb.
Ok, thanks for letting me know
