High CPU usage on SG350
Cando2011
cisco-sg350-28
firmware: 2.1.0.60
five seconds: 100%; one minute: 100%; five minutes: 100
Input Rate to CPU is 5 pps
we have permanent 100 percent cpu usage on the switch. Is there a way to see which process it is? On our Cisco 3750 there can i see "sh proc cpu".
Best regards
Cando
riteshsh
My name is Ritesh Sharma from Cisco TAC.
Please upgrade the Firmare of the device to latest.
Also disable the following and check:  Discovery Bonjour, SNMP(if not using and enabled), Jumbo Frames.
Please enable Port Fast and BPDU Guard.
Monitor the switch and check if CPU utilization is low.
Please mark this as helpful if it resolved your query.
Ritesh Sharma
Cisco TAC
davicleo.ortiz2
Hola,
Tengo el mismo problema  tengo perdidas hacia el equipo, alguna solución por favor.
Saludos Cordiales.
