how add CLI - switch SF 200 - 48
miroslaw.nowak
I hava a switch Cisco Small Business SF 200-48 and I need add CLI
I don't know how?
Somebody help me?
Best Regards
chrebert
Level 4
Level 4
The 200 series switches do not have a CLI interface.  For that you would need a 300 series or higher.  Your only option for configuring the 200 series is through the web interface.
Is there something you are trying to do that isn't working through the web GUI?
Hope that helps,
Christopher Ebert - Advanced Network Support Engineer
Cisco Small Business Support Center
*please rate helpful posts*
Hello
Thank you for reply.
I need install MRTG, now I don't remember command for switch to install this, bad teacher told me your SF 200-48 haven't CLI and I can't use MRTG in my switch :(
The older versions of the 200 series firmware did not have SNMP.  However if you upgrade to the latest version and log into the GUI you can go into Security >> TCP/UDP Services and enable SNMP.  Then go down to the SNMP section to configure according to your MRTG settings.
MRTG itself is a program that resides on a computer or server somewhere, which then sends SNMP requests to the switch, which responds with various bits of information.
The SNMP info available from the 200 series is not as extensive as something you would get from a Catalyst switch, but you can at the least get things like port status, speed, duplex, packet counts, etc.
Hope that helps,
Hello
Ok. After upgraded all will be working? (configuration - vlan etc.)
Upgrade will erase nvram?
Best Regards
