how connect Router tplink to Switch 350x
Kareem55qq
Hi ,
I Have Switch 350X after completing config vlan , I want connect router tplink and access internet to Some Vlans
Plz Help for that
thanks alot
Kareem55QQ
SG350 switches are L3 and you can configure routing and ACLs. you can use ACLs to limit/allow traffic. you can add default route towards tplink router. make sure IP addressing is correct. use below for startup.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/350_/2_3/quick_start/guide/en-US/Cisco350-QSG-en-US.pdf
Good luck
KB
