Hi I have a switch which is dismounted from production environment. What can I do to copy the current IOS image from flash to tftp server and upgrade the IOS and copy from TFTp server to the switch. Do I have have to fist delete the config to perform this action. Also since it is not in production environment how should I connect it to the PC. and IP configuration?
spanning-tree mode rapid-pvst
spanning-tree portfast default
spanning-tree portfast bpduguard default
spanning-tree vlan 20 priority 61440
errdisable recovery cause bpduguard
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause storm-control
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
switchport access vlan 20
switchport mode access
storm-control broadcast level 40.00
storm-control multicast level 40.00
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
