How Many VLAN IDs have ESW-520-24-K9?
gonzalez.daniel
I need to know hay many VLAN IDs support this product.
Thks,
Daniel.
5 Replies 5
Jo Kern
Range is VLAN ID 2 to 4093.
Maximum Total number of VLANs = 256
Thanks for the answer! I have another question about this switch... i read that use IOS... so, they support protocols like SSH or TLS?
Daniel.
the switch does not support IOS
no cli support
http based configuration probably with https (ssl)
i need to check
jo
iTyped with my iThumbs
Am 15.01.2011 um 22:00 schrieb "gonzalez.daniel" :
Joachim Kern,
A new message was posted in the Discussion thread "How Many VLAN IDs have ESW-520-24-K9?":
https://supportforums.cisco.com/message/3270789#3270789
Author : gonzalez.daniel
Profile : https://supportforums.cisco.com/people/gonzalez.daniel
Message:
there is no CLI support, the switch does have a menu based console interface which is menu based and can be used for resetting the switch or other basic configs.
This interface can be accessed on the local serial port or via telnet and ssh.
Other access methods:
