12-27-2020 05:36 AM
I want to add a SG350-10P to my SG300-28 switch.
The SG300-28 is setup as L3 in a router on stick configuration.
How to a I configure the SG350-10p and the Sg300-28?
Any help will be greatly appreciated
David Stevenson
Solved! Go to Solution.
12-27-2020 07:48 AM
Make a Trunk port between these switches :
SG350-10P (select port x/x) - Trunk---(select port x/x) SG300-28
below guide help you.
12-27-2020 07:48 AM
12-27-2020 10:49 PM
Hi Balaji
Thanks for your Reply
Does the SG350-10P need to be setup as L3 as well.
Regards David
12-28-2020 04:37 AM
Hi Balaji
Thanks I got it to work with your solution
Regards David
