How to add VLAN to trunk port on Cisco SF200-24
Olkolpiseth1
Hello All,
I have question want to ask:
I have Cisco switch SF200-24 I want to configuration VLAN as below:
Port 1 to 10 = Vlan 100
Port 11 to 21 = Vlan 200
Port 22 to 24 = Vlan 300
Port GE1 = Trunking (Primary)
Port GE2 = Trunking (Secondary)
How to add all VLAN 100, 200, 300 go through Trunking Primary and Secondary?
Which port can I connect for management switch?
Michal Bruncko
Level 4
Level 4
firstly set those ports as trunks via "VLAN Management" -> "Interface settings" - click on corresponding port, click on "edit.." button and select "Trunk" from list.
Once those ports (GE1 and GE2) are as trunks, you can now assign them all desired VLANs via "VLAN Management" -> "Port VLAN Membership". Select first port (GE1), click "join VLAN" and select all desired VLANs from left list and put them to right list.
and you are done.
by default, switch management IP is a part of default VLAN1. If you wanted to keep access to your switch, assign "VLAN1" to one of access ports, or change management VLAN to different number than 1 - but in this case dont forget to apply correct IP settings in order to meet subnet assigned in new VLAN.
Michal Bruncko
Level 4
Level 4
and you are done.
Hello Michal,
It is working now with Trunking and Management.
Thanks for fast respond
