Plug and Play for Cisco Small Business 300 Series Managed Switch
pvanvuuren
Level 3
Level 3
Good day
what are the Auto-Install options available for the Cisco Small Business 300 Series Managed Switch ?
It would appear there are none, the operating system is not the standard IOS I'm used to.
Would like to use it with Cisco Prime Infrastructure's PnP Gateway capability.
Pierre
Yiu Kay Lee
Prime Infrastructure uses and assumes a CNS (Cisco Network Services) agent on the other side when enabling "plug & play". 300/500 Series do not run IOS and does not include a CNS agent, but there is a way to enable auto-configuration. The switches support DHCP Autoconfiguration (using DHCP options 66, 67, and others) whereby they automatically download their config from a TFTP server at boot time. This allows an administrator to put the configs for all the switches on a TFTP server and simply boot a factory-defaulted switch in order to get its config.
Attached is a document showing how this is done.
Hope the information would be of assistance.
Yiu Kay Lee
Thanks Yiu - this is most helpfull.
Is there a way to use the TFTP capability of the Cisco Prime server then ?
Perhaps place full config for the switch instead of the "usual" bootstrap config.
Cheers
Pierre
