10-20-2024 11:33 PM
Please guide me how to enable dhcp snooping on CBS250 i tried the command: ip dhcp snooping but it doesn't work thanks
10-21-2024 12:17 AM
check upgrading the firmware and test it. you enter that command not recognized so that not took effective.
check other thread have same issue :
10-21-2024 12:25 AM
Hello @hoa-cv
For DHCP Snooping to function on a CBS250, it needs to be enabled both globally and for specific VLANs.
Try also in GUI...CBS250 series switches are designed with a simplified interface to cater to small and medium-sized businesses, and their CLI does not include advanced configuration commands...
10-21-2024 12:42 AM
Can you send me the tutorial file or step by step tutorial link? Thanks a lot.
10-21-2024 12:59 AM
Refer here please:
https://gzhls.at/blob/ldb/7/b/a/d/1a91d8f5204aaaff39026d9ed3a2178cba63.pdf
'DHCP Relay'
10-21-2024 01:59 AM
I need to configure DHCP snooping to set up trust port without setting up DHCP relay
10-21-2024 02:10 AM
Ok @hoa-cv
so CBS350 could do it, but not the CBS250.
