CBS250-24T-4G DHCP Snooping support
mdimitrov
Hello there,
I have struggling to locate DHCP Snooping options with this model. Even the Administration guide gives info for CBS250 series to support DHCP Snooping.
Anyone with any info about this option.
6 Replies 6
balaji.bandi
how about here :
check video also helpful
https://www.youtube.com/watch?v=JnnBN7IpOdU
BB
I can't find the menu, I saw the video perfect but its not available?
Adding screenshot.
mdimitrov
I don't know how it is possible to give available commands in CLI Guide for the series but in reality it could not be setup like you have cross-reference...
even i looked lower model 220 on the emulator I can see that option
check firmware and upgrade to 2.0.0.17
BB
Yeah I looked in the emulator also, but after tried the first available old firmware for the cbs250. The feature is missing???
I am shocked how that is possible?
The unit will be RMA-ed and swapped for CBS220 series. Hope that will solve the need.
Sure if that missing then you need to upgrade the version support or contact SMB TAC
BB
