how to edit SLM2008 switch.cfg?
eric_jantzen
I want have a default switch.cfg and I want just modify  the IP address before import.
It is possible to edit the  switch.cfg?
I try with a text editor, but file may have binary  parts.
Thank's
alissitz
Level 4
Level 4
Here is a similar discussion:
https://supportforums.cisco.com/message/3103539#3103539
Try and maintain the same formatting as the file is 'sensitive' to errors.
Do please let us know how you make out. HTH,
Andrew Lissitz
eric_jantzen
ok,
but with the SLM2008, I don't have a texte config file
Here is the init config file.
Thank's
Thanks for posting this. Humm .. a bummer the file formats are not the same across all the platforms ...
Yes, I see what you mean.
I do not see a way either, and my searches have not uncovered anything.
Sorry I am not as much help to you as I would have liked to be, perhaps another on this community will have an answer.
Kindest regards,
Andrew
