How to send both vlans to srw224 switch?
mcbereket
Hello
I configured uc540 and spa525g s working without problem. But i can only send one vlan to cisco switch. If I send vlan 100 via expansion port I cannot access the vlan 1 network on the cisco switch else the phones are not registered. I heard about configuring uc540 as a vlan trunk but i don't know how to do it? Can anyone help me?
Alberto Montilla
Dear sir;
I suggest you open a case with the Small Business Support Center. Should be able to help you on this.
Regards;
Alberto
I moved it sir. Thank you
