03-08-2013 08:22 PM
Hello, I have a SML2008 smart switch. I want to set a static IP to each port.. is this possible? Thank you
03-09-2013 03:28 AM
Hi Patric, this is not possible on this device
-Tom
Please mark answered for helpful posts
03-09-2013 11:32 AM
Thank you Tom. Is it possible to set specific ports to a DCHP range?
03-09-2013 01:29 PM
Hi Patric, this switch does not support any layer 3 functions. It is strictly a layer 2 device. There won't be much creativity on this box. If you have a router/dhcp server that supports it, you could make a vlan for each port then have the DHCP server dish out specific addressess for each vlan.
That's pretty much the extent of creativity you'll find with this switch.
-Tom
03-09-2013 02:53 PM
Hi Tom,
Perfect, that will work. I have not worked with Vlan before but I think can figure that out.
