Hybrid Stack SG350X 48p & SG350XG 2F10 crash
henrihoffmann
the 2F10 (unit2) crashed today. The upstream links to 2*SG550XG were dead till rebooting the whole stack.
Is this a know issue? Btw. the stack is for availability reasons....
FW: 2.3.5.63
2147483090 2018-May-31 05:38:06 Error %UDLD-E-MALFORMED_TLV: UDLD message from cached with illegal tlv. UDLD parsing error: errorUnsupportedVersion. mac 40a6e8ea765e
2147483197 2018-Jul-15 11:17:30 Alert %STCK SYSL-A-UNITMSG: UNIT ID 2,Msg: ***** END OF FATAL ERROR ***** ***** END OF FATAL ERROR *****
2147483198 2018-Jul-15 11:17:30 Alert %STCK SYSL-A-UNITMSG: UNIT ID 2,Msg:%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0xa0000020 signal-num = 11 (SIGSEGV) signal-code = 1 ( SEGV_MAPERR) reg[00] = 0xa0000022 reg[01] = 0x939e481b reg[02] = 0x0 reg[03] = 0x0 reg[04] = 0x9f0ff778 reg[05] = 0xa0000020 reg[06] = 0x939e481c reg[ 07] = 0x939e481b reg[08] = 0x939e459c reg[09] = 0x8 reg[10] = 0x3f FP = 0x3e8 IP = 0x1f69290 SP = 0xab5feb90 LR = 0x640cc4 PC = 0x640cbc CPSR = 0x60000 010 Fault Address = 0xa0000020 Trap no = 0xe Err Code = 0x815 Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: SYLG. Software Version: 2.3.5.63
2147483457 2018-Jul-14 15:29:19 Alert %STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:/lib/libpthread.so.0(+0x6e64) [0xb6f02e64] ***** END OF FATAL ERROR ***** ***** END OF FATAL ERROR *****
2147483458 2018-Jul-14 15:29:19 Alert %STCK SYSL-A-UNITMSG: UNIT ID 1,Msg:%SYSLOG-F-OSFATAL: caught segmentation fault exception at address 0x1b3547c signal-num = 11 (SIGSEGV) signal-code = 2 (S EGV_ACCERR) reg[00] = 0x1 reg[01] = 0x20 reg[02] = 0x1b3547d reg[03] = 0xa reg[04] = 0x25f5094 reg[05] = 0x1b35444 reg[06] = 0x40 reg[07] = 0x0 reg[0 8] = 0x1 reg[09] = 0x0 reg[10] = 0x0 FP = 0x217ed58 IP = 0x20 SP = 0x535fea68 LR = 0x8225d4 PC = 0x822614 CPSR = 0x20000010 Fault Address = 0x1b3547c Trap no = 0xe Err Code = 0x81f Old Mask = 0x0 ***** FATAL ERROR ***** Reporting Task: EVRX. Software Version: 2.3.5.63 (date Aug 20 2017 time 19:03:04)
ktonev
Based on this output I can suggest a couple of things:
1. You can see that UDLD threw an error message which means that it detected a unidirectional link. This could be caused by a bad cable/SFP so you can try to change those.
2. You are currently running firmware version 2.3.5. The latest firmware for the SG350xx is 2.4.0 so I can suggest to upgrade.
