SG550XG-24F Stack
ilsacco
it is possible to stack two sg550xg-24f using an "sfp-h10gb-cu" cable , and manage them as a unique switch of 48 ports?
in this case, should i configure a LAG between two port on different switches? (ex xg1 on sw1 and xg1 on sw2) in way to have 20 gb of link.
ktonev
Yes, the SFP-H10GB-CU1M/3M/5M is on the list of support modules for SG550XG.
As far as your second question, it depends on what you are trying to achieve. Please note that even if you bundle 2 x 10Gb ports, you won't have 20GB to any one device at a time.
Thanks for the ansewer,
but the question still remains:
If i stack two sg550xg-24, with one cable from the "stack management" menu,
i see a unique appliance of 48 ports? or the second switch  works as back mode?
Both devices (or as many as you have in the stack) will be managed under a single IP address as if it was a single unit.
Thank you for replay,
but i don't understand,
I see, one switch with 48 ports? Yes or no?
