Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3212 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4761 Views
  • 1 replies
  • 16 Helpful votes
Kindly I am stacking 4 switches SG350X-24P. For the master switch , I am using two SFP+ ports for ring stacking. For the other two SFP+ ports , I will be using the other two ports for fiber up-link. I want to valide this design, is it tested by anyon...
sallyonsy by Level 1
  • 856 Views
  • 1 replies
We purchased a SF300. Topology as follows   Cisco 2921 (voice gateway) --->SF300 ---> Juniper SRX   I cannot seem to get the Spanning tree on the SF300 and the Cisco 2921 to recognize each other.  I have found posts where it's stated to put the SF300...
JVezinat by Level 1
  • 855 Views
  • 2 replies
In my server room having one SG300 layer 2 switch with layer 3 functionality , i need to restrict dhcp ip received from another lab switch, my server room switch and lab switch in connected with trunk link, i need to restrict second switch dhcp ip ad...
Yasmeen by Level 1
  • 709 Views
  • 0 replies
Hi All,   I am in the process of testing using a RADIUS server and an SG300-10 to authenticate wired clients on my network. It is mostly working but i have an strange issue which i am hoping someone can help me with. The RADIUS is configured to authe...
atemple by Level 1
  • 1029 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
