IEE802.3ad on CISCO SG300-20
a.rondini
Good Morning,
i need help to configure this switch Cisco (SG300-20) in a IEE802.3ad to link 6 ports 100Mb from another switch.
In this way i can work with a bandwith of 600Mb between Cisco and my Switch.
Can you help me to solve this problem with an useful help.
I've attacched an image of network.
Thank you for reply.
7 Replies 7
Brendan Kearney
i have an SG300-28.  i have bonded Gi25-28 and trunked several VLANs across the port-channel.  below is the relevant config lines.  you may or may not want the lldp stuff.
interface gigabitethernet25
description "Port Channel to Router"
channel-group 1 mode auto
lldp notifications enable
lldp optional-tlv port-desc sys-name sys-desc sys-cap 802.3-mac-phy 802.3-lag 802.3-max-frame-size
lldp management-address automatic
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface Port-channel1
switchport mode general
switchport general allowed vlan add 2-3,25,37,50,52,253-255 tagged
switchport general pvid 255
Hi, thank you for reply.
But i can use only Web configuration of this switch.
Can you help me in this way?
Thank you for your help.
Hi Andrea, a link aggregation can be made in one of two ways. The easiest (and best way) in my opinion is a static LAG. A LAG is like any regular port with the exception it uses multiple links as 1 logical link.
To make a "static LAG" here are some sequential pictures.
The above pictures are making a static LAG. The LAG configuration must match the same on each side. The physical port numbers are irrelevant so long as they are connecting to a member of a LAG group.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I've done like you said, but my bandwith it's the same!
It's like i've 6 single channel at 100Mb/s not one at 600 Mb/s.
I've tried to transfer a big file between this network but i can download only a 100Mb/s .
How do you measure this?
The transfer will only operate to the slowest media. Meaning if you have a LAG between switches and you have 2 computers transferring a file between them, your transfer will only be 100 mbit because there is only 1 connection to the computers.
-Tom
the 300 series devices only allow for LACP with 802.3ad, which does not give you the total bandwidth of all interfaces in a LAG.  from what i have been able to find, the balance-xor port-channelling method is what you are looking for, but i think only the 500 series of devices supports that in the SMB market.
I've linked a PC at 100Mb to a first switch and i've reduced bandiwth to 2Mb of prots of last switch before Cisco and i've transferred file between two PC, the first at switch and the second to a CISCO in LAG modality.
So, the max bandwith is 2Mb instead 4Mb (union of 2 ports).
Can you help me?
