Install SonicPoint through SRW224G4P switch to Sonicwall
kirkwatson
I want to install a SonicPoint on an existing SRW224G4P switch.  Sonicwall architecture uses VLAN to support multiple SSID on SonicPoint.  Sonicwall interface X0 attached to port e12 on the switch, and the Sonicpoint on e24, which is PoE enabled.  In this configuration I can see the Sonicpoint is OPERATIONAL  as seen on the sonicwall, so there is some communication between the two.  Additionally, a laptop can see the SSID broadcast, and attach in a “limited” manner, but IPCONFIG shows no IP addresses being set.  Oddly, it Windows Update may have worked overnight in this configuration.  However, I cannot access the LAN or WAN from the laptop.
Where am I going wrong in the switch VLAN configuration?
I followed guidelines in http://www.brandontek.com/networking/solution-to-your-sonicpoint-wlan-woes/ but this article uses Cisco 2960G to set up VLAN.
Note DHCP service is set up for the two VLANS on the Sonicwall.
SWITCH CONFIGURATION:
     VLAN Mgt >> Create a LAN:
          1 DefaultVLAN Static
          20 SonicpointN Corporate Static
          30 SonicpointN  Guest Static
     VLAN >> Port Settings
          Port e12 TRUNK PVID =1 Ingress Filter Enabled
          Port e24 ACCESS PVID=20 Ingress Filter Enabled
          OTHERS ACCESS PVID=1
     VLAN >> Ports to LAN
          VLAN=1, Static
               Port e12 Trunk, Untagged
               Port e24 Access, Excluded
               OTHERS Access, Untagged
     VLAN=20, Static
               Port e12 Trunk, Tagged Port
               e24 Access, Untagged
               OTHERS Access, Excluded
     VLAN=30, Static
               Port e24 Access, Untagged
Ports >>> PoE
           e24 Critical
0 Replies 0
