05-18-2011 09:48 PM
Can inter VLAN routing be done on SRW (Cisco 300 series) switches ?
05-18-2011 10:01 PM
Not on an SRW 200
05-19-2011 09:52 AM
On the 300 series, yes. IP routing for up to 32 IP inetrfaces is supported on the 300 series switches.
05-27-2011 08:54 AM
Shashikant,
In order to have inter-vlan routing you need a layer 3 device to do the routing.
As Ivor stated the switch will allow you to do place the device in layer 3 mode and at that point the switch will do the layer 3 routing for the vlans.
You only need to put ip addresses on the vlans or interfaces and use the switch as the gateway for the vlans.
At that point the switch will route between the two networks.
05-27-2011 10:40 PM
Thanx David & Ivor
06-01-2011 07:04 AM
Your most welcome. If you could post this as being answered so it helps others when looking in the community.
Thank You
