IP PBX [Asterisk / Elastix] + SG300 Issues
srsiddiqui2007
We have SG300 Switches installed in our office. Having Firmware version 1.3.0.62. Default VLAN 1 is configured only. Switch are around 2 years old and are working fine without any issue except this
For past 2-3 weeks we are facing issues with our IP PBX as inbound & outbound calls are distorted, noisy, calls getting disconnected every 2-3 minutes. These issues occur randomly within a week and not more than 30 days. Issue started occurring on both Inbound (extension to extension call) and outbound calls
FXS & FXO (trunks, analog phones) are connected to the same switch as of IP PBX Server. For testing, we have connected one 7960 to the same switch in order to be confirm if the issue lies with Switch or at IP PBX end.
Need help in diagnosing the real cause of the issue
Rosica Sareva
You may start with upgrading the firmware of the switch, as it is a very old one. Most probably the boot code will also have to be upgraded.
Then a packet capture can be made on the switch to found more details on why the calls are being disconnected, from which side and if you can hear the noise on the switch side as well.
If you have a log from the PBX, you can also paste it here for review.
If you need assistance with the upgrade and taking the packet capture from the switch, please, give us a call to open a support case and an engineer will assist you with this. Contact numbers are:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Thank you!
