Is the non POE cbs220-8g-2sfp-smart-switch 12volt?
Thundagar
I can't find any information that specifies if it is or not, only that it may or may not use an adapter. if it uses an adapter is this 12v output?
balaji.bandi
Not sure if i understand correctly - is the question is the input to the device using 12V Dc power adaptor
check the datasheet for power input :
https://www.cisco.com/c/en/us/products/collateral/switches/business-220-series-smart-switches/datasheet-c78-744915.html
BB
EDIT: "yes that is the question :)"
From what i can find in that document it seems to use an external power adapter, what is the output of this adapter?
I'm replacing a SG330-10 which used 12v dc. We are hooking it up to a battery backup system where we can output both 12v and 24v dc.
