Showing results forĀ
Search instead forĀ
Did you mean:Ā
Is there a Small Business Switches with more than 8 network pools?
sangjun park
The sg300 can have up to eight network pools.
wycalero
Good Morning,
After verifying this issue you are correct, none of the Small Business Switches allow you to create more than 8 DHCP pools, if you need more you can go ahead and use a Small Business Router like the RV340.
Regards.
SG500-28 maximum ip dhcp pool hosts can have more than  up to eight network pools in Small Business Switches
