Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
Labels
Update: This portion of the project has finished earlier than initial projections. We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board fro...
CoreyP319 by Cisco Employee
  • 2363 Views
  • 0 replies
  • 1 Helpful votes
Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Installation Guide - Catalyst 1300 Hardware Installation Guide - Catalyst ...
  • 7010 Views
  • 4 replies
  • 17 Helpful votes
HiI have a switch sg300-28 without fan and not show temp. I see that in motherboard is point to solder plug for fans and I test and it give on one pin 12V and on second about 3.3V.Is any chance to solder plug and connect fan. It works ok but in GUI n...
pepeEL by Level 1
  • 3355 Views
  • 7 replies
Hi, it is my first post, sorry but my english is very bad!!! I want to know how am i do to change the Vlan1`s IP address because the actual ip will be used in another vlan. Actually i haver 10 vlans in L3 mode (routing) implemented in it.I hope you u...
Javiermo0 by Level 1
  • 3939 Views
  • 6 replies
I'm trying to uplink a CiscoSG500 switch to a Meraki MS320 switch that has it's port 22 as Trunk Native VLAN 1, allowed VLANs all. I've connected the SG switch to port 22 on the MS320. My MS320 is connected to our firewall (MX100). The SG switch is s...
pg2241 by Level 1
  • 1420 Views
  • 5 replies
Resolved! LLDP Voice VLAN
I'm setting up a Switchvox PBX with Digium D40 phones and Cisco SG200 switches.  The PBX doesn't do any CDP or LLDP advertizing so I do not expect the switch to automatically determine the voice VLAN ID and I need to manually set it.  How can I confi...
pauldugas by Level 1
  • 30091 Views
  • 14 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
