Legacy PoE on SG200-08P?
guillaume.f
I saw the annoucement stating that "200 and 300 Switches now supports Cisco Pre-standard POE" available here:
https://supportforums.cisco.com/docs/DOC-18337
However, I cannot find the 1.1.1.8 firmware for the SG200-08P in the download center (latest is 1.0.1.0).
Does this mean this doesn't apply to the SG200-08P?
If it doesn't apply, any other switches with 16 or less all gigabit ports which support legacy PoE?
Thanks.
David Hornstein
Level 7
Level 7
I noticed in CCA release notes two versions of the  200 series switches were not supported by Cisco Configuration Assistant . To me this means that these two switches are not using version 1.1.1.8
Have a chat to the good folk of SBSC, they can track down if the reason for the current software not being available for your switch.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Not that it's any consolation, but I also confirmed your finding.
Regards Dave
