SG 300 web admin interface does not display properly
lamont
Went to log into the web admin interface on my SG-300 today and I get this in both IE and Firefox:
http://dl.dropbox.com/u/21195515/cisco.png
I'm not able to login by typing user/password and just pressing enter. I've tried power-cycling the switch, and this didn't help, however, since the power cycle, the font-panel system LED has been blinking green. I seem to recall, though I can't locate the reference now, that this means the switch is running with factory settings, but that cannot be right because:
1. I had previously saved a new configuration on the switch, which it should be using now.
2. It is answering on the configured non-factory IP address -- just not rendering the web admin interface successfully.
I've had this unit for approximately a month. This is not the first issue I have had with this unit (see:
https://supportforums.cisco.com/message/3486734) and I'm experiencing some strange LAN speed issues since I installed it. Do I need to RMA this thing?
David Hornstein
Level 7
Level 7
Hi Lamont
There was a issue and work around for a issue with IE in the release notes, it may be relevant to you.
http://www.cisco.com/en/US/docs/switches/lan/csbms/sf30x_sg30x/release_notes/Sx200-Sx300_R1.1.1.8.pdf
Problem: Some WEB GUI pages require full version compatibility of JRE, Browser and JRE-Browser applets. For XML compatibility reasons, MSXML DLL Version 6 is required for IE browser users.
Solution: For download and installation please refer the following link: www.microsoft.com/downloads/details.aspx?FamilyID=993C0BCF-3BCF-4009-
BE21-27E85E1857B1&displaylang=en
This may or may not be relevant to you.  I would like to think that you are using 1.1.1.8 ?
If you really are experiencing some weird problems , why not get the product verified by the Good folk at the Small Business Support Center.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Regards Dave
