Linksys SRW2024 - I can't connect to the console
angelo1969
Hello
During the the firmware upload I had a crash (unfortunately!). I was doing it it by webview.
Now, I'm not able to access the switch anymore. The whole funtionality is gone.
I try to connect to the switch by using the serial interface, but this newer worked on my switch. (-> That's why I decide to install the newest firmware)
- I know the HyperTerminal configuration and I used 2 different serial cables (a nameless and the blue cisco console cable (Rollover Cable)).
With those cables I can connect without any Problems to cisco Pix, cisco ASA5505, diverse cisco routers and also to newest dell switches.
But I can't access the Linksys switch!
In the Linksys forum I got the answer: "You must use the cable that came with the switch". Unfortunately I can't find that cable in my assortment.
Please, could you tell me if the SRW2024 differs from the blue cisco console cable? If yes, where can I organize a such cable? Or can you tell me the pinouts of the DB9-Pin. Thank you very much.
David Hornstein
Level 7
Level 7
Hi Angelo,
OK , I pulled out my multimeter and checked the pinouts on my console cable i use to connect to my SRW2008P.
My SRW2008P, which should be the same cable as the SRW2024 the pinouts on the two femal DB9 connectors are 1 to 1.
In other words readily available cable with the following pinout;
1-------------1
2-------------2
3-------------3
4-------------4
5-------------5
6-------------6
7-------------7
8-------------8
9-------------9
regards Dave
5 Replies 5
David Hornstein
Level 7
Level 7
Hi Angelo,
1-------------1
2-------------2
3-------------3
4-------------4
5-------------5
6-------------6
7-------------7
8-------------8
9-------------9
regards Dave
Hi Dave, thanks for the info. I have organized a "straight trough" serial cable and now I can connect to the switch using the hyperterminal. ;-)
All,
Not that I don't trust you Dave, but I performed this test with a multi-meter today as well. I have unfortunately described this cable as a rollover in the past. Needless to say, my multi-meter testing confirmed your findings exactly. Seeing is believing.
Chris
Hi Chris,
According to our Mothers only -  of course we are perfect..
But I know otherwise... regards Dave
I have referenced Dave's post this week, nicely done.
Rock on Dave!
