I can't figure out how to configure a port membership with multiple VLANs. My setup:
- VLAN10
- VLAN20
- port settings tab: port24 in general mode
- ports to VLANs tab: untagged everywhere, when I set port 24 membership to VLAN10 I can't set port 24 membership in VLAN20 because when I do that port 24 membership in VLAN10 dissapears and vice versa
- but I can set port 24 membership to both VLANs in VLANs to port tab, but I think it doesn't work because:
- when I connect hosts to ports 23 (port 23 is a member of VLAN10 only) and 24 (member of VLAN10 and VLAN20)
there are not any connectivity between them
- but connectivity is working when I set the same PVID for both ports 23 and 24 in port setting tab, I can't set multiple PVID in here.
So, is it possible to configure port membership for multiple VLANs on this linksys?
http://ui.linksys.com/files/SRW2048/1.2.1/home.htm
