locate device in a network with IP address
sayharson
If I have a network consists of one core switch (L3) with the IP address, say 1.2.3.4, and several edge switches (L2), all of which are Cisco switches, and I got a report saying that the user with IP address, say 1.2.3.5 (and 1.2.3.4 is the gateway of it), is doing something bad. Now I want to track this user's physical location (e.g. on port 1 of edge switch A) so that I can do something about it (maybe sending a warning). What would be the most efficient way to do it?
Deepak Kumar
Try this:
Run below command on the Core Switch:
show arp 1.2.3.4
Switch#show arp  1.2.3.4
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  1.2.3.4              0   080a.20a1.0b50  ARPA   Vlan10
Copy the Hardware address from the output:
Run below command:
traceroute mac <source MAC address> <Destination MAC address>
here source mac-address you can keep as your machine address and Destination will be "080a.20a1.0b50" (mac address of IP address 1.2.3.4)
You will get the details.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Try this:
show arp 1.2.3.4
Run below command:
Deepak Kumar,
Leo Laohoo
In addition to Deepak, if the user is doing something stupid, I'd shut the port down. ;)
