Looking for a suitable power supply for Cisco SG 350-10.
cradiffx12
Hello guys,
i bought a Cisco SG 350-10 switch privately a while ago. Only later did I see that there was no power supply included. Unfortunately I can no longer return the device. Can someone tell me which power supply I need for this switch ? On the back it only says 12v DC. thank you and best regrads
marce1000
  - Apparently they are powered using an adapter : https://www.amazon.com/Compatible-SG350-10P-K9-EU-Ethernet-Commutateur-administarable/dp/B09X7FVVS3
 M.
marce1000
 M.
cradiffx12
Hi marce1000,
i don't think the power supply connection will fit.
best regrads
 - Examine these alternatives and scrutinize the pictures for a fit :
             https://www.ebay.com/sch/i.html?_from=R40&_trksid=p4432023.m570.l1313&_nkw=cisco+sg350-10+power+supply&_sacat=0
 M.
