multiple vlans but shared uplink
ilicalalex
I have 8 apartments that have a single internet connection coming into the building, I then have a PoE Access Point in each of the 8x apartments.
What I would like to be able to do is to have each apartment within its own vlan, but to be able to use the internet via one of the non-PoE ports (port 9 say) but do not want residents in different flats to be able to see each others devices on the same network.
I have a Cisco SG 300-10MP which has 8x PoE ports and 2x Ethernet ports, one of which my Internet connection is plugged into (using WiMax).
Apologies if it is the wrong place to locate the question, or if it is a fundamental solution which would do the trick, but I certainly welcome any advice.
Thanks in advance!
David Hornstein
Level 7
Level 7
Hi Alex,
Check out protected ports at, it is designed for MDU or hospitality environment.;
https://supportforums.cisco.com/message/3230516#3230516\
regards Dave
Dave,
Thank you for pointing me in the right direction - I was sure it must be a basic/common request, im just out of touch with the correct terminology.
Appreciate such a quick response though and a very informative one too!
Alex
